Xbox one PDP controller not working
Hi all, hopefully anyone of you can help me with this issue.
I recently bought myself a 3rd party Xbox One controller (made by a company called PDP) as a replacement for the official one that I had smashed (after my dogs used it as a chew toy) but for some reason my system picks it up but doesn't detect any button presses on it. When connected (via usb, and doesn't mater which port on pc) a little light above the 'Home' button doesn't light up, but it is still detected via lsusb. I have tried with 'xpad', 'steamos-xpad', and 'xboxdrv' and no such luck.
Below is the full output of inxi -F
  Host: willbeone-desktop Kernel: 4.18.8-2-MANJARO x86_64 bits: 64
  Desktop: N/A Distro: Manjaro Linux
  Type: Desktop Mobo: MSI model: B350M MORTAR (MS-7A37) v: 1.0   serial: <root required> UEFI: American Megatrends v: 1.G0 date: 07/27/2018
  Topology: 6-Core model: AMD Ryzen 5 2600 bits: 64 type: MT MCP
  L2 cache: 3072 KiB
  Speed: 1559 MHz min/max: 1550/3400 MHz Core speeds (MHz): 1: 1559 2: 1557
  3: 1286 4: 1272 5: 3140 6: 2490 7: 2231 8: 2236 9: 1700 10: 1313 11: 2567
  12: 2799
  Card-1: NVIDIA GP106 [GeForce GTX 1060 6GB] driver: nouveau v: kernel
  Display: x11 server: N/A driver: nouveau unloaded: modesetting
  resolution: <xdpyinfo missing>
  OpenGL: renderer: NV136 v: 4.3 Mesa 18.1.6
  Card-1: NVIDIA GP106 High Definition Audio driver: snd_hda_intel
  Card-2: AMD Family 17h HD Audio driver: snd_hda_intel
  Sound Server: ALSA v: k4.18.8-2-MANJARO
  Card-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet   driver: r8168
  IF: enp24s0 state: up speed: 100 Mbps duplex: full mac: 30:9c:23:63:70:88
  Local Storage: total: 5.79 TiB used: 3.20 TiB (55.2%)
  ID-1: /dev/sda vendor: SanDisk model: SDSSDA120G size: 111.79 GiB
  ID-2: /dev/sdb vendor: Seagate model: ST4000DM000-1F2168 size: 3.64 TiB
  ID-3: /dev/sdc vendor: A-Data model: SU650 size: 223.57 GiB
  ID-4: /dev/sdd type: USB vendor: Seagate model: Expansion Desk  size: 1.82 TiB
  ID-1: / size: 109.08 GiB used: 8.14 GiB (7.5%) fs: ext4 dev: /dev/sda1
  ID-2: /home size: 219.06 GiB used: 124.29 GiB (56.7%) fs: ext4 dev: /dev/sdc1
  System Temperatures: cpu: 44.4 C mobo: N/A gpu: nouveau temp: 35 C
  Fan Speeds (RPM): N/A gpu: nouveau fan: 931
  Processes: 293 Uptime: 47m Memory: 7.80 GiB used: 2.21 GiB (28.3%)
  Shell: bash inxi: 3.0.20
Below is the output of lsusb with the controller disconnected:
Bus 006 Device 002: ID 0bc2:331a Seagate RSS LLC
Bus 006 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 005 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 002: ID 2109:0811 VIA Labs, Inc. Hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 002: ID 0c45:7603 Microdia
Bus 001 Device 003: ID 258a:1007
Below is the output of lsusb with the controller connected:
Bus 001 Device 011: ID 0e6f:02a2 Logic3
Possibly fixed in 4.20-rc6
