I did a clean reinstall without additional programs, and autologin is still bugged, so i can comfirm that the problem is that something is broken in lightdm. And you can select a theme in lightdm settings. But the problem is, even lxdm is broken and doesnt work, so i guess the problem is somewhere deeper, and something in xorg stack or somewhere else is broken.
Let's investigate again then. Please post some info (using </> for formatting in the post, please) :
inxi -SMGIxxz
mhwd -li
cat /etc/X11/xorg.conf.d/*.conf
cat /etc/lightdm/*.conf | grep -ve "^#"
cat /var/log/Xorg.*.log
sudo cat /var/log/lightdm/lightdm*.log
journalctl -b -u lightdm
Also, with ext-monitor plugged in:
xrandr
[myname@azeroth ~]$ inxi -SMGIxxz
System: Host: azeroth Kernel: 4.17.0-2-MANJARO x86_64 bits: 64 compiler: gcc v: 8.1.1 Desktop: N/A
dm: lightdm Distro: Manjaro Linux 17.1.10 Hakoila
Machine: Type: Laptop System: Acer product: Aspire E5-571G v: V1.32 serial: <filter> Chassis: type: 10
serial: <filter>
Mobo: Acer model: EA50_HB v: V1.32 serial: <filter> UEFI [Legacy]: Insyde v: 1.32 date: 09/15/2015
Graphics: Card-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0a16
Card-2: NVIDIA GM108M [GeForce 840M] driver: nouveau v: kernel bus ID: 03:00.0 chip ID: 10de:1341
Display: x11 server: N/A driver: intel,nouveau unloaded: fbdev,modesetting,nv,vesa
compositor: compton resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.1.1 compat-v: 3.0 direct render: Yes
Info: Processes: 180 Uptime: 1m Memory: 5.75 GiB used: 894.6 MiB (15.2%) Init: systemd v: 238 Compilers:
gcc: 8.1.1 Shell: bash v: 4.4.19 running in: xfce4-terminal inxi: 3.0.10
[myname@azeroth ~]$ mhwd -li
> Installed PCI configs:
NAME VERSION FREEDRIVER TYPE
network-r8168 2016.04.20 true PCI
[myname@azeroth ~]$ cat /etc/X11/xorg.conf.d/*.conf
# Read and parsed by systemd-localed. It's probably wise not to edit this file
# manually too freely.
Section "InputClass"
Identifier "system-keyboard"
MatchIsKeyboard "on"
Option "XkbLayout" "us"
Option "XkbModel" "pc105"
EndSection
[myname@azeroth ~]$ cat /etc/lightdm/*.conf | grep -ve "^#"
[keyring]
[LightDM]
run-directory=/run/lightdm
[Seat:*]
greeter-session=lightdm-gtk-greeter
user-session=xfce
session-wrapper=/etc/lightdm/Xsession
autologin-user=myname
[XDMCPServer]
[VNCServer]
[greeter]
background = /home/myname/Documents/wallpaper.jpg
font-name = Cantarell 12
xft-antialias = true
icon-theme-name = Numix-Circle
screensaver-timeout = 0
theme-name = Numix
cursor-theme-name = xcursor-breeze
show-clock = false
default-user-image = #avatar-default
xft-hintstyle = hintfull
position = 50%,center 50%,center
clock-format =
panel-position = bottom
indicators = ~host;~spacer;~clock;~spacer;~language;~session;~a11y;~power
hide-user-image = true
[UserList]
minimum-uid=1000
hidden-users=nobody nobody4 noaccess
hidden-shells=/bin/false /usr/bin/nologin
[myname@azeroth ~]$ cat /var/log/Xorg.*.log
[ 6.987]
X.Org X Server 1.19.6
Release Date: 2017-12-20
[ 6.987] X Protocol Version 11, Revision 0
[ 6.987] Build Operating System: Linux 4.17.0-1-MANJARO x86_64
[ 6.987] Current Operating System: Linux azeroth 4.17.0-2-MANJARO #1 SMP PREEMPT Fri Jun 8 07:13:17 UTC 2018 x86_64
[ 6.987] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.17-x86_64 root=UUID=6cddda15-713b-4d79-b684-b03f76663eaf rw quiet
[ 6.987] Build Date: 20 May 2018 06:17:37PM
[ 6.987]
[ 6.987] Current version of pixman: 0.34.0
[ 6.987] Before reporting problems, check http://wiki.x.org
[ 6.987] Markers: (--) probed, (**) from config file, (==) default setting,
[ 6.988] (==) Log file: "/var/log/Xorg.0.log", Time: Tue Jun 12 20:34:51 2018
[ 6.988] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 6.988] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 6.988] (==) No Layout section. Using the first Screen section.
[ 6.988] (==) No screen section available. Using defaults.
[ 6.988] (**) |-->Screen "Default Screen Section" (0)
[ 6.988] (**) | |-->Monitor "<default monitor>"
[ 6.988] (==) No monitor specified for screen "Default Screen Section".
[ 6.988] (==) Automatically adding devices
[ 6.989] (==) Automatically enabling devices
[ 6.989] (==) Automatically adding GPU devices
[ 6.989] (==) Automatically binding GPU devices
[ 6.989] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 6.989] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 6.989] Entry deleted from font path.
[ 6.989] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[ 6.989] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 6.989] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 6.989] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 6.989] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 6.989] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/
[ 6.989] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 6.989] (II) The server relies on udev to provide the list of input devices.
[ 6.989] (II) Loader magic: 0x5585f7ab5d40
[ 6.989] (II) Module ABI versions:
[ 6.989] X.Org ANSI C Emulation: 0.4
[ 6.989] X.Org Video Driver: 23.0
[ 6.989] X.Org XInput driver : 24.1
[ 6.989] X.Org Server Extension : 10.0
[ 6.989] (++) using VT number 7
[ 6.989] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 6.990] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 6.997] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 6.998] (--) PCI:*(0:0:2:0) 8086:0a16:1025:0866 rev 11, Mem @ 0xb3000000/4194304, 0xc0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 6.998] (--) PCI: (0:3:0:0) 10de:1341:1025:0867 rev 162, Mem @ 0xb2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
[ 6.999] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 6.999] (II) LoadModule: "glx"
[ 6.999] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 6.999] (II) Module glx: vendor="X.Org Foundation"
[ 7.000] compiled for 1.19.6, module version = 1.0.0
[ 7.000] ABI class: X.Org Server Extension, version 10.0
[ 7.000] (==) Matched intel as autoconfigured driver 0
[ 7.000] (==) Matched nouveau as autoconfigured driver 1
[ 7.000] (==) Matched nv as autoconfigured driver 2
[ 7.000] (==) Matched intel as autoconfigured driver 3
[ 7.000] (==) Matched modesetting as autoconfigured driver 4
[ 7.000] (==) Matched fbdev as autoconfigured driver 5
[ 7.000] (==) Matched vesa as autoconfigured driver 6
[ 7.000] (==) Assigned the driver to the xf86ConfigLayout
[ 7.000] (II) LoadModule: "intel"
[ 7.000] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 7.000] (II) Module intel: vendor="X.Org Foundation"
[ 7.000] compiled for 1.19.6, module version = 2.99.917
[ 7.000] Module class: X.Org Video Driver
[ 7.000] ABI class: X.Org Video Driver, version 23.0
[ 7.000] (II) LoadModule: "nouveau"
[ 7.000] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 7.000] (II) Module nouveau: vendor="X.Org Foundation"
[ 7.000] compiled for 1.19.3, module version = 1.0.15
[ 7.000] (II) LoadModule: "nv"
[ 7.000] (WW) Warning, couldn't open module nv
[ 7.000] (II) UnloadModule: "nv"
[ 7.000] (II) Unloading nv
[ 7.000] (EE) Failed to load module "nv" (module does not exist, 0)
[ 7.000] (II) LoadModule: "modesetting"
[ 7.000] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 7.000] (II) Module modesetting: vendor="X.Org Foundation"
[ 7.000] compiled for 1.19.6, module version = 1.19.6
[ 7.000] (II) LoadModule: "fbdev"
[ 7.000] (WW) Warning, couldn't open module fbdev
[ 7.000] (II) UnloadModule: "fbdev"
[ 7.000] (II) Unloading fbdev
[ 7.000] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 7.000] (II) LoadModule: "vesa"
[ 7.000] (WW) Warning, couldn't open module vesa
[ 7.000] (II) UnloadModule: "vesa"
[ 7.000] (II) Unloading vesa
[ 7.000] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 7.000] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
i810, i810-dc100, i810e, i815, i830M, 845G, 854, 852GM/855GM, 865G,
915G, E7221 (i915), 915GM, 945G, 945GM, 945GME, Pineview GM,
Pineview G, 965G, G35, 965Q, 946GZ, 965GM, 965GME/GLE, G33, Q35, Q33,
GM45, 4 Series, G45/G43, Q45/Q43, G41, B43
[ 7.001] (II) intel: Driver for Intel(R) HD Graphics
[ 7.001] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 7.001] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 7.001] (II) NOUVEAU driver
[ 7.001] (II) NOUVEAU driver for NVIDIA chipset families :
[ 7.001] RIVA TNT (NV04)
[ 7.001] RIVA TNT2 (NV05)
[ 7.001] GeForce 256 (NV10)
[ 7.001] GeForce 2 (NV11, NV15)
[ 7.001] GeForce 4MX (NV17, NV18)
[ 7.001] GeForce 3 (NV20)
[ 7.001] GeForce 4Ti (NV25, NV28)
[ 7.001] GeForce FX (NV3x)
[ 7.001] GeForce 6 (NV4x)
[ 7.001] GeForce 7 (G7x)
[ 7.001] GeForce 8 (G8x)
[ 7.001] GeForce GTX 200 (NVA0)
[ 7.001] GeForce GTX 400 (NVC0)
[ 7.001] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 7.001] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180308
[ 7.001] (II) intel(0): SNA compiled from 2.99.917-829-gd7dfab62
[ 7.001] (WW) Falling back to old probe method for modesetting
[ 7.001] (II) [drm] nouveau interface version: 1.3.1
[ 7.002] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4400
[ 7.002] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 2 threads
[ 7.002] (II) intel(0): Creating default Display subsection in Screen section
"Default Screen Section" for depth/fbbpp 24/32
[ 7.002] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 7.002] (==) intel(0): RGB weight 888
[ 7.002] (==) intel(0): Default visual is TrueColor
[ 7.002] (II) intel(0): Output eDP1 has no monitor section
[ 7.002] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 7.002] (II) intel(0): Enabled output eDP1
[ 7.002] (II) intel(0): Output DP1 has no monitor section
[ 7.002] (II) intel(0): Enabled output DP1
[ 7.002] (II) intel(0): Output HDMI1 has no monitor section
[ 7.002] (II) intel(0): Enabled output HDMI1
[ 7.002] (II) intel(0): Output HDMI2 has no monitor section
[ 7.002] (II) intel(0): Enabled output HDMI2
[ 7.002] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 7.002] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 7.002] (II) intel(0): Enabled output VIRTUAL1
[ 7.002] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[ 7.002] (--) intel(0): Output HDMI2 using initial mode 2560x1440 on pipe 1
[ 7.002] (==) intel(0): TearFree disabled
[ 7.002] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.002] (==) intel(0): DPI set to (96, 96)
[ 7.002] (II) Loading sub module "dri3"
[ 7.002] (II) LoadModule: "dri3"
[ 7.002] (II) Module "dri3" already built-in
[ 7.002] (II) Loading sub module "dri2"
[ 7.002] (II) LoadModule: "dri2"
[ 7.002] (II) Module "dri2" already built-in
[ 7.002] (II) Loading sub module "present"
[ 7.002] (II) LoadModule: "present"
[ 7.002] (II) Module "present" already built-in
[ 7.003] (--) NOUVEAU(G0): Chipset: "NVIDIA NV118"
[ 7.003] (==) NOUVEAU(G0): Depth 24, (--) framebuffer bpp 32
[ 7.003] (==) NOUVEAU(G0): RGB weight 888
[ 7.003] (==) NOUVEAU(G0): Default visual is TrueColor
[ 7.003] (==) NOUVEAU(G0): Using HW cursor
[ 7.003] (==) NOUVEAU(G0): Allowed maximum DRI level 2.
[ 7.003] (==) NOUVEAU(G0): GLX sync to VBlank enabled.
[ 7.003] (==) NOUVEAU(G0): Page flipping enabled
[ 7.003] (==) NOUVEAU(G0): Swap limit set to 1 [Max allowed 2]
[ 7.003] (==) NOUVEAU(G0): Page flipping synced to vblank by kernel.
[ 7.003] (==) NOUVEAU(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 7.003] (--) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
[ 7.003] (**) NOUVEAU(G0): Mode "2560x1440": 312.2 MHz (scaled from 0.0 MHz), 89.5 kHz, 60.0 Hz
[ 7.003] (II) NOUVEAU(G0): Modeline "2560x1440"x60.0 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync (89.5 kHz)
[ 7.003] (==) NOUVEAU(G0): DPI set to (96, 96)
[ 7.003] (II) Loading sub module "fb"
[ 7.003] (II) LoadModule: "fb"
[ 7.003] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 7.003] (II) Module fb: vendor="X.Org Foundation"
[ 7.003] compiled for 1.19.6, module version = 1.0.0
[ 7.003] ABI class: X.Org ANSI C Emulation, version 0.4
[ 7.003] (II) Loading sub module "shadowfb"
[ 7.003] (II) LoadModule: "shadowfb"
[ 7.003] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 7.003] (II) Module shadowfb: vendor="X.Org Foundation"
[ 7.003] (II) UnloadModule: "modesetting"
[ 7.003] (II) Unloading modesetting
[ 7.003] (==) Depth 24 pixmap format is 32 bpp
[ 7.004] (II) NOUVEAU(G0): Channel setup complete.
[ 7.005] (II) NOUVEAU(G0): [COPY] async initialised.
[ 7.005] (II) NOUVEAU(G0): Hardware support for Present enabled
[ 7.005] (II) NOUVEAU(G0): [DRI2] Setup complete
[ 7.005] (II) NOUVEAU(G0): [DRI2] DRI driver: nouveau
[ 7.005] (II) NOUVEAU(G0): [DRI2] VDPAU driver: nouveau
[ 7.005] (II) Loading sub module "exa"
[ 7.005] (II) LoadModule: "exa"
[ 7.005] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 7.005] (II) Module exa: vendor="X.Org Foundation"
[ 7.005] compiled for 1.19.6, module version = 2.6.0
[ 7.005] ABI class: X.Org Video Driver, version 23.0
[ 7.005] (II) EXA(256): Driver allocated offscreen pixmaps
[ 7.005] (II) EXA(256): Driver registered support for the following operations:
[ 7.005] (II) Solid
[ 7.005] (II) Copy
[ 7.005] (II) Composite (RENDER acceleration)
[ 7.005] (II) UploadToScreen
[ 7.005] (II) DownloadFromScreen
[ 7.005] (==) NOUVEAU(G0): Backing store enabled
[ 7.005] (==) NOUVEAU(G0): Silken mouse enabled
[ 7.005] (II) NOUVEAU(G0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[ 7.005] (II) NOUVEAU(G0): [XvMC] Extension initialized.
[ 7.005] (==) NOUVEAU(G0): DPMS enabled
[ 7.005] (II) NOUVEAU(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 7.005] (II) intel(0): SNA initialized with Haswell (gen7.5, gt2) backend
[ 7.005] (==) intel(0): Backing store enabled
[ 7.005] (==) intel(0): Silken mouse enabled
[ 7.005] (II) intel(0): HW Cursor enabled
[ 7.005] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 7.005] (==) intel(0): DPMS enabled
[ 7.005] (==) intel(0): Display hotplug detection enabled
[ 7.005] (II) intel(0): [DRI2] Setup complete
[ 7.005] (II) intel(0): [DRI2] DRI driver: i965
[ 7.005] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 7.005] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 7.005] (II) intel(0): hardware support for Present enabled
[ 7.005] (--) RandR disabled
[ 7.015] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 7.015] (II) AIGLX: enabled GLX_ARB_create_context
[ 7.015] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 7.015] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 7.015] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 7.015] (II) AIGLX: enabled GLX_SGI_swap_control
[ 7.015] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 7.015] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 7.015] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 7.015] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 7.015] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 7.015] (II) AIGLX: Loaded and initialized i965
[ 7.015] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 7.016] (II) NOUVEAU(G0): NVEnterVT is called.
[ 7.019] (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 7.028] (II) intel(0): switch to mode 2560x1440@60.0 on HDMI2 using pipe 1, position (0, 0), rotation normal, reflection none
[ 7.030] (II) intel(0): Setting screen physical size to 677 x 381
[ 7.057] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 7.057] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.057] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.057] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.057] (II) LoadModule: "libinput"
[ 7.058] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 7.059] (II) Module libinput: vendor="X.Org Foundation"
[ 7.059] compiled for 1.19.6, module version = 0.27.1
[ 7.059] Module class: X.Org XInput Driver
[ 7.059] ABI class: X.Org XInput driver, version 24.1
[ 7.059] (II) Using input driver 'libinput' for 'Power Button'
[ 7.059] (**) Power Button: always reports core events
[ 7.059] (**) Option "Device" "/dev/input/event3"
[ 7.059] (**) Option "_source" "server/udev"
[ 7.059] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 7.059] (II) event3 - Power Button: device is a keyboard
[ 7.059] (II) event3 - Power Button: device removed
[ 7.103] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 7.103] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 7.103] (**) Option "xkb_model" "pc105"
[ 7.103] (**) Option "xkb_layout" "us"
[ 7.104] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 7.104] (II) event3 - Power Button: device is a keyboard
[ 7.105] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 7.105] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 7.105] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.105] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.105] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.105] (**) Video Bus: always reports core events
[ 7.105] (**) Option "Device" "/dev/input/event13"
[ 7.105] (**) Option "_source" "server/udev"
[ 7.105] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 7.105] (II) event13 - Video Bus: device is a keyboard
[ 7.105] (II) event13 - Video Bus: device removed
[ 7.170] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input19/event13"
[ 7.170] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 7.170] (**) Option "xkb_model" "pc105"
[ 7.170] (**) Option "xkb_layout" "us"
[ 7.171] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 7.171] (II) event13 - Video Bus: device is a keyboard
[ 7.172] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 7.172] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 7.172] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 7.172] (**) Power Button: Applying InputClass "system-keyboard"
[ 7.172] (II) Using input driver 'libinput' for 'Power Button'
[ 7.172] (**) Power Button: always reports core events
[ 7.172] (**) Option "Device" "/dev/input/event1"
[ 7.172] (**) Option "_source" "server/udev"
[ 7.173] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.173] (II) event1 - Power Button: device is a keyboard
[ 7.173] (II) event1 - Power Button: device removed
[ 7.210] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input1/event1"
[ 7.210] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 7.210] (**) Option "xkb_model" "pc105"
[ 7.210] (**) Option "xkb_layout" "us"
[ 7.211] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 7.211] (II) event1 - Power Button: device is a keyboard
[ 7.212] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 7.212] (II) No input driver specified, ignoring this device.
[ 7.212] (II) This device may have been added with another device file.
[ 7.213] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 7.213] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 7.213] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 7.213] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 7.213] (II) Using input driver 'libinput' for 'Sleep Button'
[ 7.213] (**) Sleep Button: always reports core events
[ 7.213] (**) Option "Device" "/dev/input/event2"
[ 7.213] (**) Option "_source" "server/udev"
[ 7.214] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 7.214] (II) event2 - Sleep Button: device is a keyboard
[ 7.214] (II) event2 - Sleep Button: device removed
[ 7.250] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input2/event2"
[ 7.250] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 7.250] (**) Option "xkb_model" "pc105"
[ 7.250] (**) Option "xkb_layout" "us"
[ 7.251] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 7.251] (II) event2 - Sleep Button: device is a keyboard
[ 7.252] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 7.252] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 7.252] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 7.252] (**) Video Bus: Applying InputClass "system-keyboard"
[ 7.252] (II) Using input driver 'libinput' for 'Video Bus'
[ 7.252] (**) Video Bus: always reports core events
[ 7.252] (**) Option "Device" "/dev/input/event12"
[ 7.252] (**) Option "_source" "server/udev"
[ 7.253] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 7.253] (II) event12 - Video Bus: device is a keyboard
[ 7.253] (II) event12 - Video Bus: device removed
[ 7.316] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:38/LNXVIDEO:00/input/input18/event12"
[ 7.317] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 10)
[ 7.317] (**) Option "xkb_model" "pc105"
[ 7.317] (**) Option "xkb_layout" "us"
[ 7.318] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 7.318] (II) event12 - Video Bus: device is a keyboard
[ 7.320] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event14)
[ 7.320] (II) No input driver specified, ignoring this device.
[ 7.320] (II) This device may have been added with another device file.
[ 7.321] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event15)
[ 7.321] (II) No input driver specified, ignoring this device.
[ 7.321] (II) This device may have been added with another device file.
[ 7.322] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event16)
[ 7.322] (II) No input driver specified, ignoring this device.
[ 7.322] (II) This device may have been added with another device file.
[ 7.322] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event17)
[ 7.325] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event11)
[ 7.325] (II) No input driver specified, ignoring this device.
[ 7.325] (II) This device may have been added with another device file.
[ 7.326] (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/event8)
[ 7.326] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 7.326] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 7.326] (II) Using input driver 'libinput' for 'SYN1B7E:01 06CB:2970 Touchpad'
[ 7.326] (**) SYN1B7E:01 06CB:2970 Touchpad: always reports core events
[ 7.327] (**) Option "Device" "/dev/input/event8"
[ 7.327] (**) Option "_source" "server/udev"
[ 7.332] (II) event8 - SYN1B7E:01 06CB:2970 Touchpad: is tagged by udev as: Touchpad
[ 7.332] (II) event8 - SYN1B7E:01 06CB:2970 Touchpad: device is a touchpad
[ 7.332] (II) event8 - SYN1B7E:01 06CB:2970 Touchpad: device removed
[ 7.383] (**) Option "config_info" "udev:/sys/devices/pci0000:00/INT33C3:00/i2c-0/i2c-SYN1B7E:01/0018:06CB:2970.0005/input/input12/event8"
[ 7.383] (II) XINPUT: Adding extended input device "SYN1B7E:01 06CB:2970 Touchpad" (type: TOUCHPAD, id 11)
[ 7.383] (**) Option "AccelerationScheme" "none"
[ 7.383] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) selected scheme none/0
[ 7.383] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration factor: 2.000
[ 7.384] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration threshold: 4
[ 7.388] (II) event8 - SYN1B7E:01 06CB:2970 Touchpad: is tagged by udev as: Touchpad
[ 7.388] (II) event8 - SYN1B7E:01 06CB:2970 Touchpad: device is a touchpad
[ 7.389] (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/mouse1)
[ 7.389] (II) No input driver specified, ignoring this device.
[ 7.389] (II) This device may have been added with another device file.
[ 7.390] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 7.390] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 7.390] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 7.390] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 7.390] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 7.390] (**) AT Translated Set 2 keyboard: always reports core events
[ 7.390] (**) Option "Device" "/dev/input/event4"
[ 7.390] (**) Option "_source" "server/udev"
[ 7.391] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 7.391] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 7.391] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 7.423] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 7.423] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 12)
[ 7.423] (**) Option "xkb_model" "pc105"
[ 7.423] (**) Option "xkb_layout" "us"
[ 7.425] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 7.425] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 7.426] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 7.426] (II) No input driver specified, ignoring this device.
[ 7.426] (II) This device may have been added with another device file.
[ 7.427] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event10)
[ 7.427] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 7.427] (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 7.427] (**) Acer WMI hotkeys: Applying InputClass "system-keyboard"
[ 7.427] (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
[ 7.427] (**) Acer WMI hotkeys: always reports core events
[ 7.427] (**) Option "Device" "/dev/input/event10"
[ 7.427] (**) Option "_source" "server/udev"
[ 7.428] (II) event10 - Acer WMI hotkeys: is tagged by udev as: Keyboard
[ 7.428] (II) event10 - Acer WMI hotkeys: device is a keyboard
[ 7.428] (II) event10 - Acer WMI hotkeys: device removed
[ 7.490] (**) Option "config_info" "udev:/sys/devices/virtual/input/input10/event10"
[ 7.490] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 13)
[ 7.490] (**) Option "xkb_model" "pc105"
[ 7.490] (**) Option "xkb_layout" "us"
[ 7.491] (II) event10 - Acer WMI hotkeys: is tagged by udev as: Keyboard
[ 7.491] (II) event10 - Acer WMI hotkeys: device is a keyboard
[ 9.003] (II) intel(0): EDID vendor "CMN", prod id 5566
[ 9.003] (II) intel(0): Printing DDC gathered Modelines:
[ 9.003] (II) intel(0): Modeline "1366x768"x0.0 75.45 1366 1397 1462 1560 768 772 784 806 -hsync -vsync (48.4 kHz eP)
[ 13.885] (II) config/udev: Adding input device Kingston HyperX Pulsefire FPS Gaming Mouse (/dev/input/mouse0)
[ 13.885] (II) No input driver specified, ignoring this device.
[ 13.885] (II) This device may have been added with another device file.
[ 13.910] (II) config/udev: Adding input device SEM USB Keyboard (/dev/input/event6)
[ 13.910] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 13.910] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.910] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[ 13.910] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[ 13.910] (**) SEM USB Keyboard: always reports core events
[ 13.910] (**) Option "Device" "/dev/input/event6"
[ 13.910] (**) Option "_source" "server/udev"
[ 13.910] (II) event6 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 13.910] (II) event6 - SEM USB Keyboard: device is a keyboard
[ 13.910] (II) event6 - SEM USB Keyboard: device removed
[ 13.923] (II) libinput: SEM USB Keyboard: needs a virtual subdevice
[ 13.923] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:1A2C:2124.0002/input/input6/event6"
[ 13.923] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: MOUSE, id 14)
[ 13.923] (**) Option "AccelerationScheme" "none"
[ 13.923] (**) SEM USB Keyboard: (accel) selected scheme none/0
[ 13.923] (**) SEM USB Keyboard: (accel) acceleration factor: 2.000
[ 13.923] (**) SEM USB Keyboard: (accel) acceleration threshold: 4
[ 13.924] (II) event6 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 13.924] (II) event6 - SEM USB Keyboard: device is a keyboard
[ 13.924] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 13.924] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.924] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[ 13.924] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[ 13.924] (**) SEM USB Keyboard: always reports core events
[ 13.924] (**) Option "Device" "/dev/input/event6"
[ 13.924] (**) Option "_source" "_driver/libinput"
[ 13.924] (II) libinput: SEM USB Keyboard: is a virtual subdevice
[ 13.924] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:1A2C:2124.0002/input/input6/event6"
[ 13.924] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: KEYBOARD, id 15)
[ 13.924] (**) Option "xkb_model" "pc105"
[ 13.924] (**) Option "xkb_layout" "us"
[ 13.925] (II) config/udev: Adding input device SEM USB Keyboard (/dev/input/event5)
[ 13.925] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 13.925] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 13.925] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[ 13.925] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[ 13.925] (**) SEM USB Keyboard: always reports core events
[ 13.925] (**) Option "Device" "/dev/input/event5"
[ 13.925] (**) Option "_source" "server/udev"
[ 13.925] (II) event5 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 13.925] (II) event5 - SEM USB Keyboard: device is a keyboard
[ 13.925] (II) event5 - SEM USB Keyboard: device removed
[ 13.940] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:1A2C:2124.0001/input/input5/event5"
[ 13.940] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: KEYBOARD, id 16)
[ 13.940] (**) Option "xkb_model" "pc105"
[ 13.940] (**) Option "xkb_layout" "us"
[ 13.940] (II) event5 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 13.940] (II) event5 - SEM USB Keyboard: device is a keyboard
[ 14.004] (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event18)
[ 14.004] (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
[ 14.004] (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
[ 14.004] (**) HD WebCam: HD WebCam: Applying InputClass "system-keyboard"
[ 14.004] (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
[ 14.004] (**) HD WebCam: HD WebCam: always reports core events
[ 14.004] (**) Option "Device" "/dev/input/event18"
[ 14.004] (**) Option "_source" "server/udev"
[ 14.004] (II) event18 - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[ 14.005] (II) event18 - HD WebCam: HD WebCam: device is a keyboard
[ 14.005] (II) event18 - HD WebCam: HD WebCam: device removed
[ 14.076] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input24/event18"
[ 14.076] (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 17)
[ 14.076] (**) Option "xkb_model" "pc105"
[ 14.077] (**) Option "xkb_layout" "us"
[ 14.078] (II) event18 - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[ 14.078] (II) event18 - HD WebCam: HD WebCam: device is a keyboard
[ 14.079] (II) config/udev: Adding input device Kingston HyperX Pulsefire FPS Gaming Mouse (/dev/input/event7)
[ 14.079] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 14.079] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 14.079] (II) Using input driver 'libinput' for 'Kingston HyperX Pulsefire FPS Gaming Mouse'
[ 14.079] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: always reports core events
[ 14.079] (**) Option "Device" "/dev/input/event7"
[ 14.079] (**) Option "_source" "server/udev"
[ 14.134] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: is tagged by udev as: Mouse
[ 14.134] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device is a pointer
[ 14.134] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device removed
[ 14.196] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:0951:16BC.0003/input/input7/event7"
[ 14.197] (II) XINPUT: Adding extended input device "Kingston HyperX Pulsefire FPS Gaming Mouse" (type: MOUSE, id 18)
[ 14.197] (**) Option "AccelerationScheme" "none"
[ 14.197] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: (accel) selected scheme none/0
[ 14.197] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: (accel) acceleration factor: 2.000
[ 14.197] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: (accel) acceleration threshold: 4
[ 14.254] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: is tagged by udev as: Mouse
[ 14.254] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device is a pointer
[ 15.455] (II) event8 - SYN1B7E:01 06CB:2970 Touchpad: device removed
[ 3909.438]
[ 3909.438] X Protocol Version 11, Revision 0
[ 3909.438] Build Operating System: Linux 4.17.0-1-MANJARO x86_64
[ 3909.438] Current Operating System: Linux azeroth 4.17.0-1-MANJARO #1 SMP PREEMPT Mon Jun 4 04:42:32 UTC 2018 x86_64
[ 3909.438] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-4.17-x86_64 root=UUID=6cddda15-713b-4d79-b684-b03f76663eaf rw quiet
[ 3909.438] Build Date: 20 May 2018 06:17:37PM
[ 3909.438]
[ 3909.438] Current version of pixman: 0.34.0
[ 3909.438] Before reporting problems, check http://wiki.x.org
[ 3909.438] Markers: (--) probed, (**) from config file, (==) default setting,
[ 3909.438] (==) Log file: "/var/log/Xorg.1.log", Time: Sat Jun 9 14:38:12 2018
[ 3909.438] (==) Using config directory: "/etc/X11/xorg.conf.d"
[ 3909.438] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[ 3909.438] (==) No Layout section. Using the first Screen section.
[ 3909.438] (==) No screen section available. Using defaults.
[ 3909.438] (**) |-->Screen "Default Screen Section" (0)
[ 3909.438] (**) | |-->Monitor "<default monitor>"
[ 3909.438] (==) No monitor specified for screen "Default Screen Section".
[ 3909.438] (==) Automatically adding devices
[ 3909.438] (==) Automatically enabling devices
[ 3909.438] (==) Automatically adding GPU devices
[ 3909.438] (==) Automatically binding GPU devices
[ 3909.438] (==) Max clients allowed: 256, resource mask: 0x1fffff
[ 3909.438] (WW) The directory "/usr/share/fonts/OTF/" does not exist.
[ 3909.438] Entry deleted from font path.
[ 3909.438] (WW) The directory "/usr/share/fonts/Type1/" does not exist.
[ 3909.438] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/100dpi/".
[ 3909.438] (Run 'mkfontdir' on "/usr/share/fonts/100dpi/").
[ 3909.438] (WW) `fonts.dir' not found (or not valid) in "/usr/share/fonts/75dpi/".
[ 3909.438] (Run 'mkfontdir' on "/usr/share/fonts/75dpi/").
[ 3909.438] (==) FontPath set to:
[ 3909.438] (==) ModulePath set to "/usr/lib/xorg/modules"
[ 3909.438] (II) The server relies on udev to provide the list of input devices.
[ 3909.438] (II) Loader magic: 0x560b2c941d40
[ 3909.438] (II) Module ABI versions:
[ 3909.438] X.Org ANSI C Emulation: 0.4
[ 3909.438] X.Org Video Driver: 23.0
[ 3909.438] X.Org XInput driver : 24.1
[ 3909.438] X.Org Server Extension : 10.0
[ 3909.439] (++) using VT number 8
[ 3909.439] (II) systemd-logind: logind integration requires -keeptty and -keeptty was not provided, disabling logind integration
[ 3909.440] (II) xfree86: Adding drm device (/dev/dri/card0)
[ 3909.440] (II) xfree86: Adding drm device (/dev/dri/card1)
[ 3909.442] (--) PCI:*(0:0:2:0) 8086:0a16:1025:0866 rev 11, Mem @ 0xb3000000/4194304, 0xc0000000/268435456, I/O @ 0x00005000/64, BIOS @ 0x????????/131072
[ 3909.442] (--) PCI: (0:3:0:0) 10de:1341:1025:0867 rev 162, Mem @ 0xb2000000/16777216, 0xa0000000/268435456, 0xb0000000/33554432, I/O @ 0x00003000/128
[ 3909.442] (WW) Open ACPI failed (/var/run/acpid.socket) (No such file or directory)
[ 3909.442] (II) LoadModule: "glx"
[ 3909.442] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[ 3909.443] (II) Module glx: vendor="X.Org Foundation"
[ 3909.443] compiled for 1.19.6, module version = 1.0.0
[ 3909.443] ABI class: X.Org Server Extension, version 10.0
[ 3909.443] (==) Matched intel as autoconfigured driver 0
[ 3909.443] (==) Matched nouveau as autoconfigured driver 1
[ 3909.443] (==) Matched nv as autoconfigured driver 2
[ 3909.443] (==) Matched intel as autoconfigured driver 3
[ 3909.443] (==) Matched modesetting as autoconfigured driver 4
[ 3909.443] (==) Matched fbdev as autoconfigured driver 5
[ 3909.443] (==) Matched vesa as autoconfigured driver 6
[ 3909.443] (==) Assigned the driver to the xf86ConfigLayout
[ 3909.443] (II) LoadModule: "intel"
[ 3909.443] (II) Loading /usr/lib/xorg/modules/drivers/intel_drv.so
[ 3909.443] (II) Module intel: vendor="X.Org Foundation"
[ 3909.443] compiled for 1.19.6, module version = 2.99.917
[ 3909.443] Module class: X.Org Video Driver
[ 3909.443] ABI class: X.Org Video Driver, version 23.0
[ 3909.443] (II) LoadModule: "nouveau"
[ 3909.443] (II) Loading /usr/lib/xorg/modules/drivers/nouveau_drv.so
[ 3909.447] (II) Module nouveau: vendor="X.Org Foundation"
[ 3909.447] compiled for 1.19.3, module version = 1.0.15
[ 3909.447] Module class: X.Org Video Driver
[ 3909.447] ABI class: X.Org Video Driver, version 23.0
[ 3909.447] (II) LoadModule: "nv"
[ 3909.447] (WW) Warning, couldn't open module nv
[ 3909.447] (II) UnloadModule: "nv"
[ 3909.447] (II) Unloading nv
[ 3909.447] (EE) Failed to load module "nv" (module does not exist, 0)
[ 3909.447] (II) LoadModule: "modesetting"
[ 3909.448] (II) Loading /usr/lib/xorg/modules/drivers/modesetting_drv.so
[ 3909.448] (II) Module modesetting: vendor="X.Org Foundation"
[ 3909.448] compiled for 1.19.6, module version = 1.19.6
[ 3909.448] Module class: X.Org Video Driver
[ 3909.448] ABI class: X.Org Video Driver, version 23.0
[ 3909.448] (II) LoadModule: "fbdev"
[ 3909.448] (WW) Warning, couldn't open module fbdev
[ 3909.448] (II) UnloadModule: "fbdev"
[ 3909.448] (II) Unloading fbdev
[ 3909.448] (EE) Failed to load module "fbdev" (module does not exist, 0)
[ 3909.448] (II) LoadModule: "vesa"
[ 3909.448] (WW) Warning, couldn't open module vesa
[ 3909.448] (II) UnloadModule: "vesa"
[ 3909.448] (II) Unloading vesa
[ 3909.448] (EE) Failed to load module "vesa" (module does not exist, 0)
[ 3909.448] (II) intel: Driver for Intel(R) Integrated Graphics Chipsets:
[ 3909.448] (II) intel: Driver for Intel(R) HD Graphics
[ 3909.448] (II) intel: Driver for Intel(R) Iris(TM) Graphics
[ 3909.448] (II) intel: Driver for Intel(R) Iris(TM) Pro Graphics
[ 3909.448] (II) NOUVEAU driver
[ 3909.448] (II) NOUVEAU driver for NVIDIA chipset families :
[ 3909.448] RIVA TNT (NV04)
[ 3909.448] RIVA TNT2 (NV05)
[ 3909.448] GeForce 256 (NV10)
[ 3909.448] GeForce 2 (NV11, NV15)
[ 3909.448] GeForce 4MX (NV17, NV18)
[ 3909.448] GeForce 3 (NV20)
[ 3909.448] GeForce 4Ti (NV25, NV28)
[ 3909.448] GeForce FX (NV3x)
[ 3909.448] GeForce 6 (NV4x)
[ 3909.449] GeForce 7 (G7x)
[ 3909.449] GeForce 8 (G8x)
[ 3909.449] GeForce GTX 200 (NVA0)
[ 3909.449] GeForce GTX 400 (NVC0)
[ 3909.449] (II) modesetting: Driver for Modesetting Kernel Drivers: kms
[ 3909.449] (II) intel(0): Using Kernel Mode Setting driver: i915, version 1.6.0 20180308
[ 3909.449] (II) intel(0): SNA compiled from 2.99.917-829-gd7dfab62
[ 3909.449] (WW) Falling back to old probe method for modesetting
[ 3909.449] (II) [drm] nouveau interface version: 1.3.1
[ 3909.449] (--) intel(0): Integrated Graphics Chipset: Intel(R) HD Graphics 4400
[ 3909.449] (--) intel(0): CPU: x86-64, sse2, sse3, ssse3, sse4.1, sse4.2, avx, avx2; using a maximum of 2 threads
[ 3909.449] (II) intel(0): Creating default Display subsection in Screen section
[ 3909.449] (==) intel(0): Depth 24, (--) framebuffer bpp 32
[ 3909.449] (==) intel(0): RGB weight 888
[ 3909.449] (==) intel(0): Default visual is TrueColor
[ 3909.450] (II) intel(0): Output eDP1 has no monitor section
[ 3909.450] (**) intel(0): Found backlight control interface intel_backlight (type 'raw') for output eDP1
[ 3909.450] (II) intel(0): Enabled output eDP1
[ 3909.450] (II) intel(0): Output DP1 has no monitor section
[ 3909.450] (II) intel(0): Enabled output DP1
[ 3909.450] (II) intel(0): Output HDMI1 has no monitor section
[ 3909.450] (II) intel(0): Enabled output HDMI1
[ 3909.450] (II) intel(0): Output HDMI2 has no monitor section
[ 3909.450] (II) intel(0): Enabled output HDMI2
[ 3909.450] (--) intel(0): Using a maximum size of 256x256 for hardware cursors
[ 3909.450] (II) intel(0): Output VIRTUAL1 has no monitor section
[ 3909.450] (II) intel(0): Enabled output VIRTUAL1
[ 3909.450] (--) intel(0): Output eDP1 using initial mode 1366x768 on pipe 0
[ 3909.450] (--) intel(0): Output HDMI2 using initial mode 2560x1440 on pipe 1
[ 3909.450] (==) intel(0): TearFree disabled
[ 3909.450] (==) intel(0): Using gamma correction (1.0, 1.0, 1.0)
[ 3909.450] (==) intel(0): DPI set to (96, 96)
[ 3909.450] (II) Loading sub module "dri3"
[ 3909.450] (II) LoadModule: "dri3"
[ 3909.450] (II) Module "dri3" already built-in
[ 3909.450] (II) Loading sub module "dri2"
[ 3909.450] (II) LoadModule: "dri2"
[ 3909.450] (II) Module "dri2" already built-in
[ 3909.450] (II) Loading sub module "present"
[ 3909.450] (II) LoadModule: "present"
[ 3909.450] (II) Module "present" already built-in
[ 3909.450] (--) NOUVEAU(G0): Chipset: "NVIDIA NV118"
[ 3909.450] (==) NOUVEAU(G0): Depth 24, (--) framebuffer bpp 32
[ 3909.450] (==) NOUVEAU(G0): RGB weight 888
[ 3909.450] (==) NOUVEAU(G0): Default visual is TrueColor
[ 3909.450] (==) NOUVEAU(G0): Using HW cursor
[ 3909.450] (==) NOUVEAU(G0): Allowed maximum DRI level 2.
[ 3909.450] (==) NOUVEAU(G0): GLX sync to VBlank enabled.
[ 3909.451] (==) NOUVEAU(G0): Page flipping enabled
[ 3909.451] (==) NOUVEAU(G0): Swap limit set to 1 [Max allowed 2]
[ 3909.451] (==) NOUVEAU(G0): Page flipping synced to vblank by kernel.
[ 3909.451] (==) NOUVEAU(G0): Using gamma correction (1.0, 1.0, 1.0)
[ 3909.451] (--) NOUVEAU(G0): Virtual size is 1024x768 (pitch 0)
[ 3909.451] (**) NOUVEAU(G0): Mode "2560x1440": 312.2 MHz (scaled from 0.0 MHz), 89.5 kHz, 60.0 Hz
[ 3909.451] (II) NOUVEAU(G0): Modeline "2560x1440"x60.0 312.25 2560 2752 3024 3488 1440 1443 1448 1493 -hsync +vsync (89.5 kHz)
[ 3909.451] (==) NOUVEAU(G0): DPI set to (96, 96)
[ 3909.451] (II) Loading sub module "fb"
[ 3909.451] (II) LoadModule: "fb"
[ 3909.451] (II) Loading /usr/lib/xorg/modules/libfb.so
[ 3909.451] (II) Module fb: vendor="X.Org Foundation"
[ 3909.451] compiled for 1.19.6, module version = 1.0.0
[ 3909.451] ABI class: X.Org ANSI C Emulation, version 0.4
[ 3909.451] (II) Loading sub module "shadowfb"
[ 3909.451] (II) LoadModule: "shadowfb"
[ 3909.451] (II) Loading /usr/lib/xorg/modules/libshadowfb.so
[ 3909.451] (II) Module shadowfb: vendor="X.Org Foundation"
[ 3909.451] (II) UnloadModule: "modesetting"
[ 3909.451] (II) Unloading modesetting
[ 3909.451] (==) Depth 24 pixmap format is 32 bpp
[ 3909.452] (II) NOUVEAU(G0): Channel setup complete.
[ 3909.453] (II) NOUVEAU(G0): [COPY] async initialised.
[ 3909.453] (II) NOUVEAU(G0): Hardware support for Present enabled
[ 3909.453] (II) NOUVEAU(G0): [DRI2] Setup complete
[ 3909.453] (II) NOUVEAU(G0): [DRI2] DRI driver: nouveau
[ 3909.453] (II) NOUVEAU(G0): [DRI2] VDPAU driver: nouveau
[ 3909.453] (II) Loading sub module "exa"
[ 3909.453] (II) LoadModule: "exa"
[ 3909.453] (II) Loading /usr/lib/xorg/modules/libexa.so
[ 3909.453] (II) Module exa: vendor="X.Org Foundation"
[ 3909.453] compiled for 1.19.6, module version = 2.6.0
[ 3909.453] ABI class: X.Org Video Driver, version 23.0
[ 3909.453] (II) EXA(256): Driver allocated offscreen pixmaps
[ 3909.453] (II) EXA(256): Driver registered support for the following operations:
[ 3909.453] (II) Solid
[ 3909.453] (II) Copy
[ 3909.453] (II) Composite (RENDER acceleration)
[ 3909.453] (II) UploadToScreen
[ 3909.453] (II) DownloadFromScreen
[ 3909.453] (==) NOUVEAU(G0): Backing store enabled
[ 3909.453] (==) NOUVEAU(G0): Silken mouse enabled
[ 3909.453] (II) NOUVEAU(G0): [XvMC] Associated with Nouveau GeForce 8/9 Textured Video.
[ 3909.453] (II) NOUVEAU(G0): [XvMC] Extension initialized.
[ 3909.453] (==) NOUVEAU(G0): DPMS enabled
[ 3909.453] (II) NOUVEAU(G0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 3909.453] (II) intel(0): SNA initialized with Haswell (gen7.5, gt2) backend
[ 3909.453] (==) intel(0): Backing store enabled
[ 3909.453] (==) intel(0): Silken mouse enabled
[ 3909.453] (II) intel(0): HW Cursor enabled
[ 3909.453] (II) intel(0): RandR 1.2 enabled, ignore the following RandR disabled message.
[ 3909.453] (==) intel(0): DPMS enabled
[ 3909.454] (==) intel(0): Display hotplug detection enabled
[ 3909.454] (II) intel(0): [DRI2] Setup complete
[ 3909.454] (II) intel(0): [DRI2] DRI driver: i965
[ 3909.454] (II) intel(0): [DRI2] VDPAU driver: va_gl
[ 3909.454] (II) intel(0): direct rendering: DRI2 DRI3 enabled
[ 3909.454] (II) intel(0): hardware support for Present enabled
[ 3909.454] (--) RandR disabled
[ 3909.462] (II) AIGLX: enabled GLX_MESA_copy_sub_buffer
[ 3909.463] (II) AIGLX: enabled GLX_ARB_create_context
[ 3909.463] (II) AIGLX: enabled GLX_ARB_create_context_profile
[ 3909.463] (II) AIGLX: enabled GLX_EXT_create_context_es{,2}_profile
[ 3909.463] (II) AIGLX: enabled GLX_INTEL_swap_event
[ 3909.463] (II) AIGLX: enabled GLX_SGI_swap_control
[ 3909.463] (II) AIGLX: enabled GLX_EXT_framebuffer_sRGB
[ 3909.463] (II) AIGLX: enabled GLX_ARB_fbconfig_float
[ 3909.463] (II) AIGLX: enabled GLX_EXT_fbconfig_packed_float
[ 3909.463] (II) AIGLX: GLX_EXT_texture_from_pixmap backed by buffer objects
[ 3909.463] (II) AIGLX: enabled GLX_ARB_create_context_robustness
[ 3909.463] (II) AIGLX: Loaded and initialized i965
[ 3909.463] (II) GLX: Initialized DRI2 GL provider for screen 0
[ 3909.463] (II) NOUVEAU(G0): NVEnterVT is called.
[ 3909.467] (II) intel(0): switch to mode 1366x768@60.0 on eDP1 using pipe 0, position (0, 0), rotation normal, reflection none
[ 3909.475] (II) intel(0): switch to mode 2560x1440@60.0 on HDMI2 using pipe 1, position (0, 0), rotation normal, reflection none
[ 3909.476] (II) intel(0): Setting screen physical size to 677 x 381
[ 3909.506] (II) config/udev: Adding input device Power Button (/dev/input/event3)
[ 3909.506] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3909.506] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3909.506] (**) Power Button: Applying InputClass "system-keyboard"
[ 3909.506] (II) LoadModule: "libinput"
[ 3909.506] (II) Loading /usr/lib/xorg/modules/input/libinput_drv.so
[ 3909.507] (II) Module libinput: vendor="X.Org Foundation"
[ 3909.507] compiled for 1.19.6, module version = 0.27.1
[ 3909.507] Module class: X.Org XInput Driver
[ 3909.507] ABI class: X.Org XInput driver, version 24.1
[ 3909.507] (II) Using input driver 'libinput' for 'Power Button'
[ 3909.507] (**) Power Button: always reports core events
[ 3909.507] (**) Option "Device" "/dev/input/event3"
[ 3909.507] (**) Option "_source" "server/udev"
[ 3909.508] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 3909.508] (II) event3 - Power Button: device is a keyboard
[ 3909.508] (II) event3 - Power Button: device removed
[ 3909.526] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXPWRBN:00/input/input3/event3"
[ 3909.526] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 6)
[ 3909.526] (**) Option "xkb_model" "pc105"
[ 3909.526] (**) Option "xkb_layout" "us"
[ 3909.527] (II) event3 - Power Button: is tagged by udev as: Keyboard
[ 3909.527] (II) event3 - Power Button: device is a keyboard
[ 3909.528] (II) config/udev: Adding input device Video Bus (/dev/input/event13)
[ 3909.528] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 3909.528] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 3909.528] (**) Video Bus: Applying InputClass "system-keyboard"
[ 3909.528] (II) Using input driver 'libinput' for 'Video Bus'
[ 3909.528] (**) Video Bus: always reports core events
[ 3909.528] (**) Option "Device" "/dev/input/event13"
[ 3909.528] (**) Option "_source" "server/udev"
[ 3909.528] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 3909.528] (II) event13 - Video Bus: device is a keyboard
[ 3909.528] (II) event13 - Video Bus: device removed
[ 3909.589] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:01/input/input14/event13"
[ 3909.589] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 7)
[ 3909.589] (**) Option "xkb_model" "pc105"
[ 3909.589] (**) Option "xkb_layout" "us"
[ 3909.590] (II) event13 - Video Bus: is tagged by udev as: Keyboard
[ 3909.590] (II) event13 - Video Bus: device is a keyboard
[ 3909.591] (II) config/udev: Adding input device Power Button (/dev/input/event1)
[ 3909.591] (**) Power Button: Applying InputClass "evdev keyboard catchall"
[ 3909.591] (**) Power Button: Applying InputClass "libinput keyboard catchall"
[ 3909.591] (**) Power Button: Applying InputClass "system-keyboard"
[ 3909.591] (II) Using input driver 'libinput' for 'Power Button'
[ 3909.591] (**) Power Button: always reports core events
[ 3909.591] (**) Option "Device" "/dev/input/event1"
[ 3909.591] (**) Option "_source" "server/udev"
[ 3909.592] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3909.592] (II) event1 - Power Button: device is a keyboard
[ 3909.592] (II) event1 - Power Button: device removed
[ 3909.623] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0C:00/input/input1/event1"
[ 3909.623] (II) XINPUT: Adding extended input device "Power Button" (type: KEYBOARD, id 8)
[ 3909.623] (**) Option "xkb_model" "pc105"
[ 3909.623] (**) Option "xkb_layout" "us"
[ 3909.624] (II) event1 - Power Button: is tagged by udev as: Keyboard
[ 3909.624] (II) event1 - Power Button: device is a keyboard
[ 3909.625] (II) config/udev: Adding input device Lid Switch (/dev/input/event0)
[ 3909.625] (II) No input driver specified, ignoring this device.
[ 3909.625] (II) This device may have been added with another device file.
[ 3909.625] (II) config/udev: Adding input device Sleep Button (/dev/input/event2)
[ 3909.626] (**) Sleep Button: Applying InputClass "evdev keyboard catchall"
[ 3909.626] (**) Sleep Button: Applying InputClass "libinput keyboard catchall"
[ 3909.626] (**) Sleep Button: Applying InputClass "system-keyboard"
[ 3909.626] (II) Using input driver 'libinput' for 'Sleep Button'
[ 3909.626] (**) Sleep Button: always reports core events
[ 3909.626] (**) Option "Device" "/dev/input/event2"
[ 3909.626] (**) Option "_source" "server/udev"
[ 3909.626] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 3909.626] (II) event2 - Sleep Button: device is a keyboard
[ 3909.626] (II) event2 - Sleep Button: device removed
[ 3909.646] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:01/PNP0C0E:00/input/input2/event2"
[ 3909.646] (II) XINPUT: Adding extended input device "Sleep Button" (type: KEYBOARD, id 9)
[ 3909.646] (**) Option "xkb_model" "pc105"
[ 3909.646] (**) Option "xkb_layout" "us"
[ 3909.647] (II) event2 - Sleep Button: is tagged by udev as: Keyboard
[ 3909.648] (II) event2 - Sleep Button: device is a keyboard
[ 3909.648] (II) config/udev: Adding input device Video Bus (/dev/input/event12)
[ 3909.649] (**) Video Bus: Applying InputClass "evdev keyboard catchall"
[ 3909.649] (**) Video Bus: Applying InputClass "libinput keyboard catchall"
[ 3909.649] (**) Video Bus: Applying InputClass "system-keyboard"
[ 3909.649] (II) Using input driver 'libinput' for 'Video Bus'
[ 3909.649] (**) Video Bus: always reports core events
[ 3909.649] (**) Option "Device" "/dev/input/event12"
[ 3909.649] (**) Option "_source" "server/udev"
[ 3909.649] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 3909.650] (II) event12 - Video Bus: device is a keyboard
[ 3909.650] (II) event12 - Video Bus: device removed
[ 3909.723] (**) Option "config_info" "udev:/sys/devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:38/LNXVIDEO:00/input/input13/event12"
[ 3909.723] (II) XINPUT: Adding extended input device "Video Bus" (type: KEYBOARD, id 10)
[ 3909.723] (**) Option "xkb_model" "pc105"
[ 3909.723] (**) Option "xkb_layout" "us"
[ 3909.724] (II) event12 - Video Bus: is tagged by udev as: Keyboard
[ 3909.724] (II) event12 - Video Bus: device is a keyboard
[ 3909.725] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=3 (/dev/input/event15)
[ 3909.725] (II) No input driver specified, ignoring this device.
[ 3909.725] (II) This device may have been added with another device file.
[ 3909.726] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=7 (/dev/input/event16)
[ 3909.726] (II) No input driver specified, ignoring this device.
[ 3909.726] (II) This device may have been added with another device file.
[ 3909.727] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=8 (/dev/input/event17)
[ 3909.727] (II) No input driver specified, ignoring this device.
[ 3909.727] (II) This device may have been added with another device file.
[ 3909.727] (II) config/udev: Adding input device HDA Intel HDMI HDMI/DP,pcm=9 (/dev/input/event18)
[ 3909.729] (II) config/udev: Adding input device SEM USB Keyboard (/dev/input/event5)
[ 3909.729] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 3909.729] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 3909.729] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[ 3909.729] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[ 3909.729] (**) SEM USB Keyboard: always reports core events
[ 3909.729] (**) Option "Device" "/dev/input/event5"
[ 3909.729] (**) Option "_source" "server/udev"
[ 3909.730] (II) event5 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 3909.730] (II) event5 - SEM USB Keyboard: device is a keyboard
[ 3909.730] (II) event5 - SEM USB Keyboard: device removed
[ 3909.769] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.0/0003:1A2C:2124.0001/input/input5/event5"
[ 3909.769] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: KEYBOARD, id 11)
[ 3909.769] (**) Option "xkb_model" "pc105"
[ 3909.769] (**) Option "xkb_layout" "us"
[ 3909.771] (II) event5 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 3909.771] (II) event5 - SEM USB Keyboard: device is a keyboard
[ 3909.772] (II) config/udev: Adding input device SEM USB Keyboard (/dev/input/event6)
[ 3909.772] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 3909.772] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 3909.772] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[ 3909.772] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[ 3909.772] (**) SEM USB Keyboard: always reports core events
[ 3909.772] (**) Option "Device" "/dev/input/event6"
[ 3909.772] (**) Option "_source" "server/udev"
[ 3909.773] (II) event6 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 3909.773] (II) event6 - SEM USB Keyboard: device is a keyboard
[ 3909.774] (II) event6 - SEM USB Keyboard: device removed
[ 3909.793] (II) libinput: SEM USB Keyboard: needs a virtual subdevice
[ 3909.793] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:1A2C:2124.0002/input/input6/event6"
[ 3909.793] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: MOUSE, id 12)
[ 3909.793] (**) Option "AccelerationScheme" "none"
[ 3909.793] (**) SEM USB Keyboard: (accel) selected scheme none/0
[ 3909.793] (**) SEM USB Keyboard: (accel) acceleration factor: 2.000
[ 3909.793] (**) SEM USB Keyboard: (accel) acceleration threshold: 4
[ 3909.794] (II) event6 - SEM USB Keyboard: is tagged by udev as: Keyboard
[ 3909.794] (II) event6 - SEM USB Keyboard: device is a keyboard
[ 3909.796] (II) config/udev: Adding input device Kingston HyperX Pulsefire FPS Gaming Mouse (/dev/input/event7)
[ 3909.796] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: Applying InputClass "evdev pointer catchall"
[ 3909.796] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: Applying InputClass "libinput pointer catchall"
[ 3909.796] (II) Using input driver 'libinput' for 'Kingston HyperX Pulsefire FPS Gaming Mouse'
[ 3909.796] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: always reports core events
[ 3909.796] (**) Option "Device" "/dev/input/event7"
[ 3909.796] (**) Option "_source" "server/udev"
[ 3909.853] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: is tagged by udev as: Mouse
[ 3909.853] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device is a pointer
[ 3909.853] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device removed
[ 3909.923] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-3/2-3:1.0/0003:0951:16BC.0003/input/input7/event7"
[ 3909.923] (II) XINPUT: Adding extended input device "Kingston HyperX Pulsefire FPS Gaming Mouse" (type: MOUSE, id 13)
[ 3909.923] (**) Option "AccelerationScheme" "none"
[ 3909.923] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: (accel) selected scheme none/0
[ 3909.923] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: (accel) acceleration factor: 2.000
[ 3909.923] (**) Kingston HyperX Pulsefire FPS Gaming Mouse: (accel) acceleration threshold: 4
[ 3909.980] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: is tagged by udev as: Mouse
[ 3909.980] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device is a pointer
[ 3909.981] (II) config/udev: Adding input device Kingston HyperX Pulsefire FPS Gaming Mouse (/dev/input/mouse0)
[ 3909.981] (II) No input driver specified, ignoring this device.
[ 3909.981] (II) This device may have been added with another device file.
[ 3909.983] (II) config/udev: Adding input device HD WebCam: HD WebCam (/dev/input/event10)
[ 3909.983] (**) HD WebCam: HD WebCam: Applying InputClass "evdev keyboard catchall"
[ 3909.983] (**) HD WebCam: HD WebCam: Applying InputClass "libinput keyboard catchall"
[ 3909.983] (**) HD WebCam: HD WebCam: Applying InputClass "system-keyboard"
[ 3909.983] (II) Using input driver 'libinput' for 'HD WebCam: HD WebCam'
[ 3909.983] (**) HD WebCam: HD WebCam: always reports core events
[ 3909.983] (**) Option "Device" "/dev/input/event10"
[ 3909.983] (**) Option "_source" "server/udev"
[ 3909.984] (II) event10 - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[ 3909.984] (II) event10 - HD WebCam: HD WebCam: device is a keyboard
[ 3909.984] (II) event10 - HD WebCam: HD WebCam: device removed
[ 3910.033] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-7/2-7:1.0/input/input10/event10"
[ 3910.033] (II) XINPUT: Adding extended input device "HD WebCam: HD WebCam" (type: KEYBOARD, id 14)
[ 3910.033] (**) Option "xkb_model" "pc105"
[ 3910.033] (**) Option "xkb_layout" "us"
[ 3910.033] (II) event10 - HD WebCam: HD WebCam: is tagged by udev as: Keyboard
[ 3910.033] (II) event10 - HD WebCam: HD WebCam: device is a keyboard
[ 3910.034] (II) config/udev: Adding input device HDA Intel PCH Headphone (/dev/input/event8)
[ 3910.034] (II) No input driver specified, ignoring this device.
[ 3910.034] (II) This device may have been added with another device file.
[ 3910.034] (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/event14)
[ 3910.034] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "evdev touchpad catchall"
[ 3910.034] (**) SYN1B7E:01 06CB:2970 Touchpad: Applying InputClass "libinput touchpad catchall"
[ 3910.034] (II) Using input driver 'libinput' for 'SYN1B7E:01 06CB:2970 Touchpad'
[ 3910.034] (**) SYN1B7E:01 06CB:2970 Touchpad: always reports core events
[ 3910.034] (**) Option "Device" "/dev/input/event14"
[ 3910.034] (**) Option "_source" "server/udev"
[ 3910.053] (II) event14 - SYN1B7E:01 06CB:2970 Touchpad: is tagged by udev as: Touchpad
[ 3910.053] (II) event14 - SYN1B7E:01 06CB:2970 Touchpad: device is a touchpad
[ 3910.053] (II) event14 - SYN1B7E:01 06CB:2970 Touchpad: device removed
[ 3910.116] (**) Option "config_info" "udev:/sys/devices/pci0000:00/INT33C3:00/i2c-0/i2c-SYN1B7E:01/0018:06CB:2970.0005/input/input16/event14"
[ 3910.116] (II) XINPUT: Adding extended input device "SYN1B7E:01 06CB:2970 Touchpad" (type: TOUCHPAD, id 15)
[ 3910.116] (**) Option "AccelerationScheme" "none"
[ 3910.116] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) selected scheme none/0
[ 3910.116] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration factor: 2.000
[ 3910.116] (**) SYN1B7E:01 06CB:2970 Touchpad: (accel) acceleration threshold: 4
[ 3910.119] (II) event14 - SYN1B7E:01 06CB:2970 Touchpad: is tagged by udev as: Touchpad
[ 3910.119] (II) event14 - SYN1B7E:01 06CB:2970 Touchpad: device is a touchpad
[ 3910.119] (II) config/udev: Adding input device SYN1B7E:01 06CB:2970 Touchpad (/dev/input/mouse1)
[ 3910.119] (II) No input driver specified, ignoring this device.
[ 3910.119] (II) This device may have been added with another device file.
[ 3910.120] (II) config/udev: Adding input device AT Translated Set 2 keyboard (/dev/input/event4)
[ 3910.120] (**) AT Translated Set 2 keyboard: Applying InputClass "evdev keyboard catchall"
[ 3910.120] (**) AT Translated Set 2 keyboard: Applying InputClass "libinput keyboard catchall"
[ 3910.120] (**) AT Translated Set 2 keyboard: Applying InputClass "system-keyboard"
[ 3910.120] (II) Using input driver 'libinput' for 'AT Translated Set 2 keyboard'
[ 3910.120] (**) AT Translated Set 2 keyboard: always reports core events
[ 3910.120] (**) Option "Device" "/dev/input/event4"
[ 3910.120] (**) Option "_source" "server/udev"
[ 3910.120] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 3910.120] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 3910.120] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 3910.156] (**) Option "config_info" "udev:/sys/devices/platform/i8042/serio0/input/input4/event4"
[ 3910.156] (II) XINPUT: Adding extended input device "AT Translated Set 2 keyboard" (type: KEYBOARD, id 16)
[ 3910.156] (**) Option "xkb_model" "pc105"
[ 3910.156] (**) Option "xkb_layout" "us"
[ 3910.157] (II) event4 - AT Translated Set 2 keyboard: is tagged by udev as: Keyboard
[ 3910.157] (II) event4 - AT Translated Set 2 keyboard: device is a keyboard
[ 3910.157] (II) config/udev: Adding input device PC Speaker (/dev/input/event9)
[ 3910.157] (II) No input driver specified, ignoring this device.
[ 3910.157] (II) This device may have been added with another device file.
[ 3910.157] (II) config/udev: Adding input device Acer WMI hotkeys (/dev/input/event11)
[ 3910.158] (**) Acer WMI hotkeys: Applying InputClass "evdev keyboard catchall"
[ 3910.158] (**) Acer WMI hotkeys: Applying InputClass "libinput keyboard catchall"
[ 3910.158] (**) Acer WMI hotkeys: Applying InputClass "system-keyboard"
[ 3910.158] (II) Using input driver 'libinput' for 'Acer WMI hotkeys'
[ 3910.158] (**) Acer WMI hotkeys: always reports core events
[ 3910.158] (**) Option "Device" "/dev/input/event11"
[ 3910.158] (**) Option "_source" "server/udev"
[ 3910.158] (II) event11 - Acer WMI hotkeys: is tagged by udev as: Keyboard
[ 3910.158] (II) event11 - Acer WMI hotkeys: device is a keyboard
[ 3910.158] (II) event11 - Acer WMI hotkeys: device removed
[ 3910.209] (**) Option "config_info" "udev:/sys/devices/virtual/input/input12/event11"
[ 3910.209] (II) XINPUT: Adding extended input device "Acer WMI hotkeys" (type: KEYBOARD, id 17)
[ 3910.209] (**) Option "xkb_model" "pc105"
[ 3910.209] (**) Option "xkb_layout" "us"
[ 3910.210] (II) event11 - Acer WMI hotkeys: is tagged by udev as: Keyboard
[ 3910.210] (II) event11 - Acer WMI hotkeys: device is a keyboard
[ 3910.244] (**) SEM USB Keyboard: Applying InputClass "evdev keyboard catchall"
[ 3910.244] (**) SEM USB Keyboard: Applying InputClass "libinput keyboard catchall"
[ 3910.244] (**) SEM USB Keyboard: Applying InputClass "system-keyboard"
[ 3910.244] (II) Using input driver 'libinput' for 'SEM USB Keyboard'
[ 3910.244] (**) SEM USB Keyboard: always reports core events
[ 3910.244] (**) Option "Device" "/dev/input/event6"
[ 3910.244] (**) Option "_source" "_driver/libinput"
[ 3910.244] (II) libinput: SEM USB Keyboard: is a virtual subdevice
[ 3910.244] (**) Option "config_info" "udev:/sys/devices/pci0000:00/0000:00:14.0/usb2/2-2/2-2:1.1/0003:1A2C:2124.0002/input/input6/event6"
[ 3910.244] (II) XINPUT: Adding extended input device "SEM USB Keyboard" (type: KEYBOARD, id 18)
[ 3910.244] (**) Option "xkb_model" "pc105"
[ 3910.244] (**) Option "xkb_layout" "us"
[ 3911.451] (II) intel(0): EDID vendor "CMN", prod id 5566
[ 3911.451] (II) intel(0): Printing DDC gathered Modelines:
[ 3911.451] (II) intel(0): Modeline "1366x768"x0.0 75.45 1366 1397 1462 1560 768 772 784 806 -hsync -vsync (48.4 kHz eP)
[ 5346.712] (II) event3 - Power Button: device removed
[ 5346.743] (II) event13 - Video Bus: device removed
[ 5346.796] (II) event1 - Power Button: device removed
[ 5346.823] (II) event2 - Sleep Button: device removed
[ 5346.849] (II) event12 - Video Bus: device removed
[ 5346.903] (II) event5 - SEM USB Keyboard: device removed
[ 5346.929] (II) event7 - Kingston HyperX Pulsefire FPS Gaming Mouse: device removed
[ 5346.983] (II) event10 - HD WebCam: HD WebCam: device removed
[ 5347.036] (II) event14 - SYN1B7E:01 06CB:2970 Touchpad: device removed
[ 5347.083] (II) event4 - AT Translated Set 2 keyboard: device removed
[ 5347.116] (II) event11 - Acer WMI hotkeys: device removed
[ 5347.169] (II) event6 - SEM USB Keyboard: device removed
[ 5347.196] (II) AIGLX: Suspending AIGLX clients for VT switch
[ 5347.229] (II) NOUVEAU(G0): NVLeaveVT is called.
[ 5347.529] (II) UnloadModule: "libinput"
[ 5347.530] (II) UnloadModule: "libinput"
[ 5347.539] (II) NOUVEAU(G0): NVLeaveVT is called.
[ 5347.539] Error dropping master: -22(Invalid argument)
[ 5347.563] (II) Server terminated successfully (0). Closing log file.
[myname@azeroth ~]$ sudo cat /var/log/lightdm/lightdm*.log
[sudo] password for myname:
cat: '/var/log/lightdm/lightdm*.log': No such file or directory
[myname@azeroth ~]$ journalctl -b -u lightdm
-- Logs begin at Sat 2018-06-09 12:25:23 EEST, end at Tue 2018-06-12 20:37:37 EEST. --
Jun 12 20:34:48 azeroth systemd[1]: Starting Light Display Manager...
Jun 12 20:34:48 azeroth systemd[1]: Started Light Display Manager.
Jun 12 20:34:51 azeroth lightdm[572]: pam_succeed_if(lightdm-autologin:auth): requirement "user ingroup autologin" was met by user "myname"
Jun 12 20:34:51 azeroth lightdm[572]: gkr-pam: no password is available for user
Jun 12 20:34:51 azeroth lightdm[572]: pam_unix(lightdm-autologin:session): session opened for user myname by (uid=0)
Jun 12 20:34:51 azeroth lightdm[572]: pam_unix(lightdm-autologin:session): session closed for user myname
Jun 12 20:34:52 azeroth lightdm[609]: pam_unix(lightdm-greeter:session): session opened for user lightdm by (uid=0)
Jun 12 20:35:00 azeroth lightdm[654]: pam_unix(lightdm:session): session opened for user myname by (uid=0)
[myname@azeroth ~]$ xrandr
Screen 0: minimum 8 x 8, current 2560 x 1440, maximum 32767 x 32767
eDP1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 340mm x 190mm
1366x768 60.01*+
1280x720 59.86 60.00 59.74
1024x768 60.00
1024x576 60.00 59.90 59.82
960x540 60.00 59.63 59.82
800x600 60.32 56.25
864x486 60.00 59.92 59.57
640x480 59.94
720x405 59.51 60.00 58.99
680x384 60.00
640x360 59.84 59.32 60.00
DP1 disconnected (normal left inverted right x axis y axis)
HDMI1 disconnected (normal left inverted right x axis y axis)
HDMI2 connected 2560x1440+0+0 (normal left inverted right x axis y axis) 550mm x 310mm
2560x1440 59.95*+ 59.95
1920x1080 60.00 50.00 59.94
1920x1080i 60.00 50.00 59.94
1600x1200 60.00
1680x1050 59.88
1280x1024 75.02 60.02
1440x900 59.90
1280x960 60.00
1280x800 59.91
1152x864 75.00
1280x720 60.00 50.00 59.94
1024x768 75.03 70.07 60.00
832x624 74.55
800x600 72.19 75.00 60.32 56.25
720x576 50.00
720x480 60.00 59.94
720x480i 60.00 59.94
640x480 75.00 72.81 66.67 60.00 59.95 59.94
720x400 70.08
VIRTUAL1 disconnected (normal left inverted right x axis y axis)
[myname@azeroth ~]$ sudo mousepad '/var/log/lightdm/lightdm.log'
[+0.00s] DEBUG: Logging to /var/log/lightdm/lightdm.log
[+0.00s] DEBUG: Starting Light Display Manager 1.26.0, UID=0 PID=375
[+0.00s] DEBUG: Loading configuration dirs from /usr/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /usr/local/share/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration dirs from /etc/xdg/lightdm/lightdm.conf.d
[+0.00s] DEBUG: Loading configuration from /etc/lightdm/lightdm.conf
[+0.00s] DEBUG: Registered seat module local
[+0.00s] DEBUG: Registered seat module xremote
[+0.00s] DEBUG: Registered seat module unity
[+0.00s] DEBUG: Using D-Bus name org.freedesktop.DisplayManager
[+0.01s] DEBUG: Monitoring logind for seats
[+0.01s] DEBUG: New seat added from logind: seat0
[+0.01s] DEBUG: Seat seat0: Loading properties from config section Seat:*
[+0.01s] DEBUG: Seat seat0: Starting
[+0.01s] DEBUG: Seat seat0: Creating user session
[+0.07s] DEBUG: Loading users from org.freedesktop.Accounts
[+0.07s] DEBUG: User /org/freedesktop/Accounts/User1000 added
[+0.15s] DEBUG: Seat seat0: Creating display server of type x
[+0.15s] DEBUG: Could not run plymouth --ping: Failed to execute child process “plymouth” (No such file or directory)
[+0.15s] DEBUG: Using VT 7
[+0.15s] DEBUG: Seat seat0: Starting local X display on VT 7
[+0.15s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+0.15s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+0.15s] DEBUG: XServer 0: Launching X Server
[+0.15s] DEBUG: Launching process 422: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+0.15s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+0.15s] DEBUG: Acquired bus name org.freedesktop.DisplayManager
[+0.15s] DEBUG: Registering seat with bus path /org/freedesktop/DisplayManager/Seat0
[+2.68s] DEBUG: Got signal 10 from process 422
[+2.68s] DEBUG: XServer 0: Got signal from X server :0
[+2.68s] DEBUG: XServer 0: Connecting to XServer :0
[+2.69s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+2.69s] DEBUG: Session pid=572: Started with service 'lightdm-autologin', username 'myname'
[+2.70s] DEBUG: Session pid=572: Authentication complete with return value 0: Success
[+2.70s] DEBUG: Seat seat0: Session authenticated, running command
[+2.70s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session0
[+2.70s] DEBUG: Session pid=572: Running command /etc/lightdm/Xsession startxfce4
[+2.70s] DEBUG: Creating shared data directory /var/lib/lightdm-data/myname
[+2.70s] DEBUG: Session pid=572: Logging to .xsession-errors
[+2.81s] DEBUG: Activating VT 7
[+2.81s] DEBUG: Activating login1 session c1
[+2.81s] DEBUG: Seat seat0 changes active session to c1
[+2.81s] DEBUG: Session c1 is already active
[+3.14s] DEBUG: Session pid=572: Exited with return value 0
[+3.14s] DEBUG: Seat seat0: Session stopped
[+3.14s] DEBUG: Seat seat0: Stopping display server, no sessions require it
[+3.14s] DEBUG: Sending signal 15 to process 422
[+3.65s] DEBUG: Process 422 exited with return value 1
[+3.65s] DEBUG: XServer 0: X server stopped
[+3.65s] DEBUG: Releasing VT 7
[+3.65s] DEBUG: XServer 0: Removing X server authority /run/lightdm/root/:0
[+3.65s] DEBUG: Seat seat0: Display server stopped
[+3.65s] DEBUG: Seat seat0: Active display server stopped, starting greeter
[+3.65s] DEBUG: Seat seat0: Creating greeter session
[+3.65s] DEBUG: Seat seat0: Creating display server of type x
[+3.65s] DEBUG: Using VT 7
[+3.65s] DEBUG: Seat seat0: Starting local X display on VT 7
[+3.65s] DEBUG: XServer 0: Logging to /var/log/lightdm/x-0.log
[+3.65s] DEBUG: XServer 0: Writing X server authority to /run/lightdm/root/:0
[+3.65s] DEBUG: XServer 0: Launching X Server
[+3.66s] DEBUG: Launching process 603: /usr/bin/X :0 -seat seat0 -auth /run/lightdm/root/:0 -nolisten tcp vt7 -novtswitch
[+3.66s] DEBUG: XServer 0: Waiting for ready signal from X server :0
[+4.22s] DEBUG: Got signal 10 from process 603
[+4.22s] DEBUG: XServer 0: Got signal from X server :0
[+4.22s] DEBUG: XServer 0: Connecting to XServer :0
[+4.22s] DEBUG: Seat seat0: Display server ready, starting session authentication
[+4.22s] DEBUG: Session pid=609: Started with service 'lightdm-greeter', username 'lightdm'
[+4.25s] DEBUG: Session pid=609: Authentication complete with return value 0: Success
[+4.25s] DEBUG: Seat seat0: Session authenticated, running command
[+4.25s] DEBUG: Session pid=609: Running command /usr/bin/lightdm-gtk-greeter
[+4.25s] DEBUG: Creating shared data directory /var/lib/lightdm-data/lightdm
[+4.25s] DEBUG: Session pid=609: Logging to /var/log/lightdm/seat0-greeter.log
[+4.31s] DEBUG: Activating VT 7
[+4.31s] DEBUG: Activating login1 session c2
[+4.31s] DEBUG: Seat seat0 changes active session to c2
[+4.32s] DEBUG: Session c2 is already active
[+4.49s] DEBUG: Greeter connected version=1.26.0 api=1 resettable=false
[+4.63s] DEBUG: Greeter start authentication for myname
[+4.63s] DEBUG: Session pid=654: Started with service 'lightdm', username 'myname'
[+4.64s] DEBUG: Session pid=654: Got 1 message(s) from PAM
[+4.64s] DEBUG: Prompt greeter with 1 message(s)
[+11.81s] DEBUG: Continue authentication
[+11.83s] DEBUG: Session pid=654: Authentication complete with return value 0: Success
[+11.83s] DEBUG: Authenticate result for user myname: Success
[+11.83s] DEBUG: User myname authorized
[+11.83s] DEBUG: Greeter sets language en_US.utf8
[+11.83s] DEBUG: Greeter requests session xfce
[+11.83s] DEBUG: Seat seat0: Stopping greeter; display server will be re-used for user session
[+11.83s] DEBUG: Terminating login1 session c2
[+11.83s] DEBUG: Session pid=609: Sending SIGTERM
[+11.84s] DEBUG: Greeter closed communication channel
[+11.84s] DEBUG: Session pid=609: Exited with return value 0
[+11.84s] DEBUG: Seat seat0: Session stopped
[+11.84s] DEBUG: Seat seat0: Greeter stopped, running session
[+11.84s] DEBUG: Registering session with bus path /org/freedesktop/DisplayManager/Session1
[+11.84s] DEBUG: Session pid=654: Running command /etc/lightdm/Xsession startxfce4
[+11.84s] DEBUG: Creating shared data directory /var/lib/lightdm-data/myname
[+11.84s] DEBUG: Session pid=654: Logging to .xsession-errors
[+11.89s] DEBUG: Activating VT 7
[+11.89s] DEBUG: Activating login1 session c3
[+11.89s] DEBUG: Seat seat0 changes active session to
[+11.89s] DEBUG: Seat seat0 changes active session to c3
[+11.89s] DEBUG: Session c3 is already active
Ok, so i added to blacklist these modules in /etc/modprobe.d/nobeep.conf:
blacklist nouveau
blacklist rivafb
blacklist nvidiafb
blacklist rivatv
blacklist nv
blacklist uvcvideo
The last few boots have been correct with auto login working, also had to set correct mouse cursor theme in /etc/lightdm/lightdm-gtk-greeter.conf, and cursor theme and size issues also went away, for now.
So this all mess seems like a fault of incorrect default manjaro configuration.
Have you also changed gpu drivers?
It seems, having dual gpu may interfere with Xorg setup. Auto-login happens and then instand logout. This nouveau
blacklisting may have isolated gpu control on Xorg initial setup.
Can you check your current Graphics and if nouveau even starts later or not at all (in Xorg logs)?
inxi -Gxx
cat /var/log/Xorg.0.log
$ inxi -Gxx
Graphics: Card-1: Intel Haswell-ULT Integrated Graphics driver: i915 v: kernel bus ID: 00:02.0
chip ID: 8086:0a16
Card-2: NVIDIA GM108M [GeForce 840M] driver: N/A bus ID: 03:00.0 chip ID: 10de:1341
Display: x11 server: N/A driver: intel unloaded: fbdev,modesetting,vesa compositor: compton
resolution: <xdpyinfo missing>
OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.1.1 compat-v: 3.0 direct render: Yes
And Xorg log doesnt show any entries about nouveau.
I am glad it is fine!
Just a reminder, you are using only Intel GPU.
