.xinitrc seems to don't get loaded at startup
Hello here,
I created a .Xresources in my home folder, to customize rxvt-unicode.
I already read this topic, but I don't understand what they did in the solution.
I checked the .xinitrc, it is the default file present on my installation, and it check if a .Xresources file is present in my home, and load it.
userresources=$HOME/.Xresources
[some bash here…]
if [ -f "$userresources" ]; then
    xrdb -merge "$userresources"
fi
If I did the command xrdb -merge manualy, the file is correctly loaded, and urxvt change !
Those lines should load my file, I think.
I tried to add this line at the begining of the .xinitrc:
echo "test" > $HOME/test.txt
And the file is never created.
I think my .xinitrc is never called anywhere.
I use GDM as login manager (I use gnome).
Maybe have a look here:
https://bbs.archlinux.org/viewtopic.php?id=184435
Thank you for the link.
I followed instructions, but it doesn't work.
But, it was a start for some research, and I found a solution:
remove the -nocpp option of /etc/gdm/Xsession file, at the line:
xrdb -nocpp -merge "$userresources"
I use this for my xterm, inside .xinitrc:
[[ -f ~/.Xresources ]] && xrdb -merge -I$HOME ~/.Xresources
