Yakuake shortcuts not work for session switch when session is greater than 4
I've been set Ctrl+1 for switch to first session, Ctrl+2 for switch to second session, ..., Ctrl+6 for switch to sixth session.
But Ctrl+5 do nothing, no response after I press these two shortcuts.
Dose anyone have been set Ctrl+5 for switch to fifth session?
My false!!!
It seems only Ctrl+5 not work, Ctrl+1,23,4,6,7,8 all worked, except 5.
Nobody encounted this situation?
I tried to set shortcuts like as you and I don't have any problem.
all working as intended.
  • Check your shortcuts again
  • Check there is not a global shortcut already mapped to ctrl+5
Thanks for your reply. But I have checked all my shortcuts times, global shortcuts, standard shortcuts, custom shortcuts.
Is there a way to export all defined shortcuts?
Below is my global shortcuts,
[ActivityManager][Global Shortcuts]
switch-to-activity-eb671dd1-d515-40d0-b024-fcf6feead964=none
[KDE Keyboard Layout Switcher][Global Shortcuts]
Disable Touchpad=Touchpad Off
Enable Touchpad=Touchpad On
Show System Activity=Ctrl+Esc
Switch to Next Keyboard Layout=Ctrl+Alt+K
Toggle Touchpad=Touchpad Toggle
display=Display; Meta+P
{1ac367b2-57ac-44e3-ab99-e9b4886ce0d4}=Meta+Shift+Print
{45df4749-4a8d-418c-a6e7-55eda17fb408}=Alt+B
{6f72d35c-ac9b-4788-8866-387771e0b0ff}=Print
{7e97d63b-c292-41ee-a982-47b335f8f17a}=Meta+Print
{7ec554b2-256a-4366-a66f-e1da03d88741}=Meta+E
{9d32f9d8-edf0-4c59-abb8-f818a9871740}=Shift+Print
{a7b7a7db-588f-4caa-9fa8-c70069a368cb}=Alt+G
{d03619b6-9b3c-48cc-9d9c-a2aadb485550}=none
{e6a002f1-44f9-4ec9-bfa1-f322d9d11a1f}=Ctrl+Alt+T
[kaccess][Global Shortcuts]
Toggle Screen Reader On and Off=Meta+Alt+S
[kmix][Global Shortcuts]
decrease_microphone_volume=Microphone Volume Down
decrease_volume=Volume Down; Ctrl+F11
increase_microphone_volume=Microphone Volume Up
increase_volume=Volume Up; Ctrl+F12
mic_mute=Microphone Mute
mute=Volume Mute
[krunner][Global Shortcuts]
run command=Alt+Space; Alt+F2; Search
run command on clipboard contents=Alt+Shift+F2
[ksmserver][Global Shortcuts]
Halt Without Confirmation=Ctrl+Alt+Shift+PgDown
Lock Session=Meta+L
Log Out=Ctrl+Alt+Del
Log Out Without Confirmation=Ctrl+Alt+Shift+Del
Reboot Without Confirmation=Ctrl+Alt+Shift+PgUp
[kwin][Global Shortcuts]
Activate Window Demanding Attention=Ctrl+Alt+A
Cube=none
Cylinder=none
Decrease Opacity=none
Expose=Ctrl+F9
ExposeAll=Ctrl+F10; Launch (C)
ExposeClass=Ctrl+F7
FlipSwitchAll=none
FlipSwitchCurrent=none
Increase Opacity=none
Invert Screen Colors=none
Kill Window=Ctrl+Alt+Esc
MoveMouseToCenter=Meta+F6
MoveMouseToFocus=Meta+F5
MoveZoomDown=none
MoveZoomLeft=none
MoveZoomRight=none
MoveZoomUp=none
Remove Window From Group=none
Setup Window Shortcut=none
Show Desktop=none
ShowDesktopGrid=Ctrl+F8
Sphere=none
Suspend Compositing=Alt+Shift+F12
Switch One Desktop Down=none
Switch One Desktop Up=none
Switch One Desktop to the Left=none
Switch One Desktop to the Right=none
Switch Window Down=Meta+Alt+Down
Switch Window Left=Meta+Alt+Left
Switch Window Right=Meta+Alt+Right
Switch Window Up=Meta+Alt+Up
Switch to Desktop 1=Ctrl+F1
Switch to Desktop 10=none
Switch to Desktop 11=none
Switch to Desktop 12=none
Switch to Desktop 13=none
Switch to Desktop 14=none
Switch to Desktop 15=none
Switch to Desktop 16=none
Switch to Desktop 17=none
Switch to Desktop 18=none
Switch to Desktop 19=none
Switch to Desktop 2=Ctrl+F2
Switch to Desktop 20=none
Switch to Desktop 3=Ctrl+F3
Switch to Desktop 4=Ctrl+F4
Switch to Desktop 5=Ctrl+F5
Switch to Desktop 6=Ctrl+F6
Switch to Desktop 7=none
Switch to Desktop 8=none
Switch to Desktop 9=none
Switch to Next Desktop=none
Switch to Next Screen=none
Switch to Previous Desktop=none
Switch to Previous Screen=none
Switch to Screen 0=none
Switch to Screen 1=none
Switch to Screen 2=none
Switch to Screen 3=none
Switch to Screen 4=none
Switch to Screen 5=none
Switch to Screen 6=none
Switch to Screen 7=none
Toggle Window Raise/Lower=none
Walk Through Desktop List=none
Walk Through Desktop List (Reverse)=none
Walk Through Desktops=none
Walk Through Desktops (Reverse)=none
Walk Through Window Tabs=none
Walk Through Window Tabs (Reverse)=none
Walk Through Windows=Alt+Tab
Walk Through Windows (Reverse)=Alt+Shift+Backtab
Walk Through Windows Alternative=none
Walk Through Windows Alternative (Reverse)=none
Walk Through Windows of Current Application=Alt+`
Walk Through Windows of Current Application (Reverse)=Alt+~
Walk Through Windows of Current Application Alternative=none
Walk Through Windows of Current Application Alternative (Reverse)=none
Window Above Other Windows=none
Window Below Other Windows=none
Window Close=Alt+F4
Window Fullscreen=none
Window Grow Horizontal=none
Window Grow Vertical=none
Window Lower=none
Window Maximize=Meta+PgUp
Window Maximize Horizontal=none
Window Maximize Vertical=none
Window Minimize=Meta+PgDown
Window Move=none
Window No Border=none
Window On All Desktops=none
Window One Desktop Down=none
Window One Desktop Up=none
Window One Desktop to the Left=none
Window One Desktop to the Right=none
Window Operations Menu=Alt+F3
Window Pack Down=none
Window Pack Left=none
Window Pack Right=none
Window Pack Up=none
Window Quick Tile Bottom=Meta+Down
Window Quick Tile Bottom Left=none
Window Quick Tile Bottom Right=none
Window Quick Tile Left=Meta+Left
Window Quick Tile Right=Meta+Right
Window Quick Tile Top=Meta+Up
Window Quick Tile Top Left=none
Window Quick Tile Top Right=none
Window Raise=none
Window Resize=none
Window Shade=none
Window Shrink Horizontal=none
Window Shrink Vertical=none
Window to Desktop 1=none
Window to Desktop 10=none
Window to Desktop 11=none
Window to Desktop 12=none
Window to Desktop 13=none
Window to Desktop 14=none
Window to Desktop 15=none
Window to Desktop 16=none
Window to Desktop 17=none
Window to Desktop 18=none
Window to Desktop 19=none
Window to Desktop 2=none
Window to Desktop 20=none
Window to Desktop 3=none
Window to Desktop 4=none
Window to Desktop 5=none
Window to Desktop 6=none
Window to Desktop 7=none
Window to Desktop 8=none
Window to Desktop 9=none
Window to Next Desktop=Ctrl+Shift+Down
Window to Next Screen=none
Window to Previous Desktop=Ctrl+Shift+Up
Window to Previous Screen=none
Window to Screen 0=none
Window to Screen 1=none
Window to Screen 2=none
Window to Screen 3=none
Window to Screen 4=none
Window to Screen 5=none
Window to Screen 6=none
Window to Screen 7=none
view_actual_size=none
view_zoom_in=Meta+=
view_zoom_out=Meta+-
[mediacontrol][Global Shortcuts]
mediavolumedown=none
mediavolumeup=none
nextmedia=Media Next
playpausemedia=Media Play
previousmedia=Media Previous
stopmedia=Media Stop
[org_kde_powerdevil][Global Shortcuts]
Decrease Keyboard Brightness=Keyboard Brightness Down
Decrease Screen Brightness=Monitor Brightness Down
Hibernate=Hibernate
Increase Keyboard Brightness=Keyboard Brightness Up
Increase Screen Brightness=Monitor Brightness Up
PowerOff=Power Off
Sleep=Sleep
Toggle Keyboard Backlight=Keyboard Light On/Off
[plasmashell][Global Shortcuts]
activate task manager entry 1=Meta+1
activate task manager entry 10=Meta+0
activate task manager entry 2=Meta+2
activate task manager entry 3=Meta+3
activate task manager entry 4=Meta+4
activate task manager entry 5=Meta+5
activate task manager entry 6=Meta+6
activate task manager entry 7=Meta+7
activate task manager entry 8=Meta+8
activate task manager entry 9=Meta+9
activate widget 117=none
activate widget 222=none
activate widget 263=Alt+F1
activate widget 274=none
clear-history=none
clipboard_action=Ctrl+Alt+X
cycleNextAction=none
cyclePrevAction=none
edit_clipboard=none
manage activities=Meta+Q
next activity=Meta+Tab
previous activity=Meta+Shift+Tab
repeat_action=Ctrl+Alt+R
show dashboard=Meta+D
show-barcode=none
show-on-mouse-pos=none
stop current activity=none
[yakuake][Global Shortcuts]
toggle-window-state=F9
And Below now is Yakuake shortcuts:
[Global Shortcuts]
[Shortcuts]
close-active-terminal=Ctrl+Shift+R
close-session=Ctrl+Shift+W
decrease-window-height=Alt+Shift+Up
decrease-window-width=Alt+Shift+Left
edit-profile=none
file_quit=Ctrl+Shift+Q
grow-terminal-bottom=Ctrl+Alt+Down
grow-terminal-left=Ctrl+Alt+Left
grow-terminal-right=Ctrl+Alt+Right
grow-terminal-top=Ctrl+Alt+Up
help_about_app=none
help_about_kde=none
help_report_bug=none
help_whats_this=Shift+F1
increase-window-height=Alt+Shift+Down
increase-window-width=Alt+Shift+Right
keep-open=none
manage-profiles=none
move-session-left=Ctrl+Shift+Left; Ctrl+Shift+H
move-session-right=Ctrl+Shift+Right; Ctrl+Shift+L
new-session=Ctrl+Shift+T
new-session-quad=none
new-session-two-horizontal=none
new-session-two-vertical=none
next-session=Shift+Right; Shift+L
next-terminal=Ctrl+Shift+Down
options_configure=Ctrl+Shift+,
options_configure_keybinding=none
options_configure_notifications=none
previous-session=Shift+Left; Shift+H
previous-terminal=Ctrl+Shift+Up
rename-session=Ctrl+Alt+S
split-left-right=Ctrl+(
split-top-bottom=Ctrl+)
switch-to-session-1=Ctrl+1
switch-to-session-10=none
switch-to-session-2=Ctrl+2
switch-to-session-3=Ctrl+3
switch-to-session-4=Ctrl+4
switch-to-session-5=Ctrl+5; Ctrl+T
switch-to-session-6=Ctrl+6
switch-to-session-7=none
switch-to-session-8=none
switch-to-session-9=none
toggle-session-keyboard-input=none
toggle-session-monitor-activity=Ctrl+Shift+A
toggle-session-monitor-silence=Ctrl+Shift+I
toggle-session-prevent-closing=none
toggle-window-state=none
view-full-screen=Ctrl+Shift+F11
As you can see I set Ctrl+5 and Ctrl+T for swith to 5 session, but only Ctrl+T worked.
Occasionally found it was fcitx advanced option(which is hide normal) set Ctrl+5 shortcut.
